here is what I found and fixed...
If your tire is new and you trust the tech that did the tire balancing..then its not a tire issue or
wheel weight issue..
Its how the wheel weights are mounted..
The best wheel weights are the ones that cramp onto the rim centerline..
But should they stick tape wheel weights on (which is typical), then make sure they or you place
the tape on wheel weights as centerline as can be.
On my bike I have a tire pressure monitor system inside my rim.
I typically have lots of wheel tape on weights cuz of it.
Once I divided up the amount of wheel weights and placed them on both sides of the center-ist place I could tape them
The front vibration did go away completely.
I also use DynaBeads in both front and rear tires..WHY..my tests reveeeeled that with them I get much more uniform tire
wear and no cupping in the front at all..
with out the dyna beads..I get cupping and less tire wear..
Terrible Ted
